8.2.3 -
Review and graph the use of shards/shards -
I want to prevent you not from having snippets available to use in elastichsearch -
What happened?
I filled up the available shards -
It didn’t record fragments -
curl -XGET http://ip:9200/_cluster/health?pretty
“cluster_name” : “elasticsearch”,
“status” : “yellow”,
“timed_out” : false,
“number_of_nodes” : 1,
“number_of_data_nodes” : 1,
“active_primary_shards” : 2500,
“active_shards” : 2500,
“relocating_shards” : 0,
“initializing_shards” : 0,
“unassigned_shards” : 2500,
“delayed_unassigned_shards” : 0,
“number_of_pending_tasks” : 0,
“number_of_in_flight_fetch” : 0,
“task_max_waiting_in_queue_millis” : 0,
“active_shards_percent_as_number” : 50.0
curl -s -XGET http://ip:9200/_cat/shards | wc -l
5000
It didn’t record data -
