Data is empty from elastic data source
I started using Elasticsearch few weeks ago, and I’m now trying to connect it with Grafana, to plot some data I have.
In particular, if I query Elasticsearch, using:
127.0.0.1:9200/indexname/_search
My data looks correct:
{“took”:3,“timed_out”:false,“_shards”:{“total”:1,“successful”:1,“skipped”:0,“failed”:0},“hits”:{“total”:{“value”:4,“relation”:“eq”},“max_score”:1.0,“hits”:[{“_index”:“XXX”,“_id”:“7ERPqoIBqpRLjSlgvXVC”,“_score”:1.0,“_source”:{
“timestamp”:“5623734345000”,
“UserType”: “ios”,
“UserId”: “8”,
“Location”: “Chennai”,
“Data”: {
“Source”:“LoginScreen”,
“VideoLoadDuration”: “100”,
“TimeSpend” : “12”,
“BytesStreamed” : “200”,
“FullVideoPlayed” : “true”,
“MetaPageVisited” : “true”,
“TimeSpentOnMetaPage” : “5”,
“TimeSpentOnChat” : “2”
},{“_index”:“mobilehacks”,“_id”:“7URRqoIBqpRLjSlgg3Vc”,“_score”:1.0,“_source”:{
“UserType”: “android”,
“UserId”: “5”,
“Data”: {
“TimeSpend” : “12”,
},{“_index”:“mobilehacks”,“_id”:“7kSQqoIBqpRLjSlg2XVX”,“_score”:1.0,“_source”:{
“timestamp”:“2022-08-17”,
“UserId”: “5”,
“Data”: {
“TimeSpend” : “12”,
},{“_index”:“mobilehacks”,“_id”:“70SSqoIBqpRLjSlgHHXi”,“_score”:1.0,“_source”:{
“UserType”: “ios”,
“UserId”: “6”,
“Location”: “Dubai”,
“Data”: {
“TimeSpend” : “12”,
I am trying the view the data in dashboard using the below query but i am getting no data
When I “Save & Test” the elastic data source, everything is fine and I get the message:
Index OK. Time field name OK.
I am using elastic version:“version” : {
“number” : “8.3.3”,
I got the below response from query inspector
“request”: {
“url”: “api/datasources/proxy/3/_msearch?max_concurrent_shard_requests=5”,
“method”: “POST”,
“data”: “{"search_type":"query_then_fetch","ignore_unavailable":true,"index":"mobilehacks"}\n{"size":500,"query":{"bool":{"filter":[{"range":{"timestamp":{"gte":1660697565184,"lte":1660719165184,"format":"epoch_millis"}}}]}},"sort":[{"timestamp":{"order":"desc","unmapped_type":"boolean"}},{"_doc":{"order":"desc"}}],"script_fields":{},"aggs":{"1":{"date_histogram":{"field":"timestamp","min_doc_count":0,"extended_bounds":{"min":1660697565184,"max":1660719165184},"format":"epoch_millis","fixed_interval":"30s"},"aggs":{}}},"highlight":{"fields":{"*":{}},"pre_tags":["@HIGHLIGHT@"],"post_tags":["@/HIGHLIGHT@"],"fragment_size":2147483647}}\n”,
“hideFromInspector”: false
“response”: {
“took”: 32,
“responses”: [
“took”: 32,
“timed_out”: false,
“_shards”: {
“total”: 1,
“successful”: 1,
“skipped”: 0,
“failed”: 0
“hits”: {
“total”: {
“value”: 0,
“relation”: “eq”
“max_score”: null,
“hits”:
“aggregations”: {
“1”: {
“buckets”: [
“key_as_string”: “1660697550000”,
“key”: 1660697550000,
“doc_count”: 0
“key_as_string”: “1660697580000”,
“key”: 1660697580000,
“doc_count”: 0
Can anyone figure out whether is issue with query or with the connection
Hello, you may want remove your personal information from your post
is that real index mobilehacks location Chennai, Dubaï
:open_mouth:
that is weird not sure i want to be part of that, but i can see data in your response, your query is working.
Welcome,
your issue is more elasticsearch than grafana. you might get more mileage on elasticsearch forum.
