HTTP API for importing dashboard
  • What Grafana version and what operating system are you using? OSS 11.0, Ubuntu Container
    I am trying to bring dashboard automatically from a json file using a REST API.
  • What happened?
    At the moment, I am looking for an API that takes json as input to some API that automatically imports it and brings up the dashboard. I am expecting some API similar to “api/dashboard/db”
JSON could be imported by Grafana Infinity Datasource:
But not sure that it is possible at all to build a dashboard dynamically from JSON that you receive via API…
May be dashboard HTTP API will be of use:
I tried using Grafana HTTP API, this did not work for me.
I have scenario where I wish to bring up dashboard exported json file from UI. Steps below:
  • User creates or updates the dashboard using Grafana UI.
  • Exports the dashboard to a json file and dump into some “X” folder.
  • My script is monitoring “X” folder for changes and triggers a HTTP request with file path
    (json file path) to bring up dashboard from the file.
Note: It is kind of similar to Grafana Provisioning but I am specifically looking for a HTTP API
Use HTTP dashboard export API first - compare result file with that export result from UI: they are not identical, but they are similar. So your script must modify that exported file from UI, to match expected structure for HTTP import.
This worked. I exported using export API and used the same JSON (with some changes as needed) with import API
