How to import dashboard in grafana using REST API
I need to import the dashboard in the Grafana using rest API, Can anyone provide me the python working code?
Hi @avinashvermajava,
You can definitely do this by using popular scripts e.g. Python or Bash (or simply with cURL command).
As a starting point, please have a look at our API Documentation here.
There are already some community posts regarding this so you can check the following links
1- Import dashboard from file via API
2- Grafana API create dashboard API with Python
Also, I recently found this (haven’t known it before) that there are now Python library functions available to do that (in just a single command line);
1- grafana-import - Python Package Health Analysis | Snyk
2- grafanalib/grafanalib/tests/examples at main · weaveworks/grafanalib · GitHub (Scripts ready to go)
and if you really want to go a bit in more hands-on then you can check this link:
I hope this helps.
