I have a “homey” smart home witch logs to a syslog-ng container running inside my docker.
I have all though a loki and grafan container running.
I would like to have the legend and tooltip names replaced with the corresponding app-names
For example this one
"labels": {
"application": "BAD_LICHT",
"facility": "local1",
"host": "homey-62456552d237d50bb470c7ef-4",
"job": "syslog",
"level": "debug",
"proc_id": "2327"
"config": {
"displayNameFromDS": "homey-62456552d237d50bb470c7ef-4"
should than be called “BAD”
Here is the result of my query inspection
Thank you!
"request": {
"url": "api/ds/query?ds_type=loki&requestId=Q259_1",
"method": "POST",
"data": {
"queries": [
"datasource": {
"type": "loki",
"uid": "P8E80F9AEF21F6940"
"editorMode": "builder",
"expr": "count_over_time({job=\"syslog\", host=~\"homey-62456552d237d50bb470c7ef-4\", level=~\"debug|informational|notice|warning|error|critical|alert|emergency\", application=~\".*\"} !~ `.*$ignore_lines_with.*` |~ `.*.*` [$__interval])",
"legendFormat": "{{host}}",
"queryType": "range",
"refId": "A",
"datasourceId": 3,
"intervalMs": 60000,
"maxDataPoints": 1028
"from": "1726729080000",
"to": "1726750723219"
"hideFromInspector": false
"response": {
"results": {
"A": {
"status": 200,
"frames": [
"schema": {
"refId": "A",
"meta": {
"type": "timeseries-multi",
"typeVersion": [
0,
1
"stats": [
"displayName": "Summary: bytes processed per second",
"unit": "Bps",
"value": 78507
"displayName": "Summary: lines processed per second",
"value": 1407
"displayName": "Summary: total bytes processed",
"unit": "decbytes",
"value": 7418
"displayName": "Summary: total lines processed",
"value": 133
"displayName": "Summary: exec time",
"unit": "s",
"value": 0.094487879
"displayName": "Ingester: total reached",
"value": 11
"displayName": "Ingester: total chunks matched",
"value": 5
"displayName": "Ingester: total batches",
"value": 22
"displayName": "Ingester: total lines sent",
"value": 37
"displayName": "Ingester: head chunk bytes",
"unit": "decbytes",
"value": 0
"displayName": "Ingester: head chunk lines",
"value": 0
"displayName": "Ingester: decompressed bytes",
"unit": "decbytes",
"value": 0
"displayName": "Ingester: decompressed lines",
"value": 0
"displayName": "Ingester: compressed bytes",
"unit": "decbytes",
"value": 0
"displayName": "Ingester: total duplicates",
"value": 0
"executedQueryString": "Expr: count_over_time({job=\"syslog\", host=~\"homey-62456552d237d50bb470c7ef-4\", level=~\"debug|informational|notice|warning|error|critical|alert|emergency\", application=~\".*\"} !~ `.*$ignore_lines_with.*` |~ `.*.*` [1m])\nStep: 1m0s"
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"frame": "time.Time"
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"application": "BAD",
"job": "syslog",
"level": "debug",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726730220000,
1726731420000,
1726732620000,
1726733820000,
1726735020000,
1726736220000,
1726745760000,
1726746960000,
1726748160000,
1726750560000
1,
1,
1,
1,
1,
1,
1,
1,
1,
1
"schema": {
"refId": "A",
"meta": {
"typeVersion": [
0,
1
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"application": "BAD_FENSTER",
"job": "syslog",
"level": "informational",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726740600000,
1726744560000
1,
1
"schema": {
"refId": "A",
"meta": {
"typeVersion": [
0,
1
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"job": "syslog",
"level": "debug",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726730220000,
1726731420000,
1726732620000,
1726733820000,
1726735020000,
1726736220000,
1726745760000,
1726746960000,
1726748160000,
1726750560000
1,
1,
1,
1,
1,
1,
1,
1,
1,
1
"schema": {
"refId": "A",
"meta": {
"typeVersion": [
0,
1
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"application": "HAC",
"facility": "user",
"job": "syslog",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726729260000,
1726732860000,
1726736460000,
1726740060000,
1726743660000,
1726747260000
1,
1,
1,
1,
1,
1
"schema": {
"refId": "A",
"meta": {
"typeVersion": [
0,
1
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"application": "SYSTEM",
"facility": "daemon",
"job": "syslog",
"level": "debug",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726740060000
1
"schema": {
"refId": "A",
"meta": {
"typeVersion": [
0,
1
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"application": "SZ1_FENSTER",
"job": "syslog",
"level": "debug",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726729140000,
1726731000000,
1726742340000,
1726743060000,
1726748340000,
1726750260000
1,
1,
1,
1,
1,
1
"schema": {
"refId": "A",
"meta": {
"typeVersion": [
0,
1
"fields": [
"name": "Time",
"type": "time",
"typeInfo": {
"config": {
"interval": 60000
"name": "Value",
"type": "number",
"typeInfo": {
"frame": "float64"
"labels": {
"application": "SZ1_LICHT",
"job": "syslog",
"level": "debug",
"proc_id": "2327"
"config": {
"data": {
"values": [
1726729140000,
1726731120000,
1726741260000,
1726741320000,
1726741980000,
1726746960000,
1726747140000,
1726747380000,
1726747440000,
1726749780000,
1726749840000,
1726749900000,
1726750260000,
1726750320000,
1726750380000,
1726750500000,
1726750680000
1,
1,
2,
2,
2,
1,
1,
1,
1,
1,
1,
2,
1,
1,
3,
1,
2
"refId": "A"
