Relabeling the legend in Grafana
0
this is my first question, so please do not stone me to death :smiley: I am running a smarthome stack containing mqtt, telegraf, influxdb2 and grafana8 using bme280 sensors. everything is running smoothly after some problems but i am having some issues renaming the legend in my grafana dashboard.
my flux query
from(bucket: "bme280")
  |> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
  |> filter(fn: (r) => r["topic"] == "sensors/bk/temp" or r["topic"] == "sensors/sz/temp" or r["topic"] == "sensors/wz/temp")
  |> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
  |> yield(name: "mean")
results in a nice graph however i donโ€™t like the legend which is
- value {host="raspi", topic="sensors/bk/temp"}
- value {host="raspi", topic="sensors/sz/temp"}
- value {host="raspi", topic="sensors/wz/temp"}
it should display
- Temperature Balcony
- Temperature Sleeping room
- Temperature living room
i can get around changing the โ€œvalueโ€ tag to something else using
|> set(key: "value", value: "temperature")
but the part in โ€œ{}โ€ is not covered. Is there any way to remove this part or at least change it? See Picture
Furthermore: Im not that good with querying language. Thus iโ€™m using the influxdb2 visual builder to complete queries and copy them into grafana. Is there a leaner way? (beside diving deeper into flux)
Thank you and BR
Welcome to the forum. First of all, nice setup! (MQTT + Telegraf + Influx2 + Grafana)
What you want is certainly possible (I had / have the same issue with Flux, where I get crazy long legend names). I would suggest you not mess with the Flux value tag and just use an Override in Grafana. In my screenshot below, the original name was Memory (yours would be value {host="raspi", topic="sensors/bk/temp"}) and the new (override) name is Temperature Balcony
Hello Grant
thank you for the warm welcome wishes. I tried out your proposed solution and it works like a charm!
Thank you so much for your reply
Best regards
Hello Grant
I have two related use cases.
  • Can this be done on a dashboard level? I tried to edit the dashboard json by overriding the override property. But no luck.
  • Is there a way to replace a substring in the label? e.g. x1-India, x1-Indonesia and s1-Japan to be replaced with xiaomi-India, xiaomi-Indonesia and samsung-Japan.
