Hi All,
Please assist me in running a number of test scripts in the K6 Distributed Environment.
I have multiple test cases, so I need to run those scripts on different EC2 machines. I looked online for articles or tutorials on this, but I couldn’t discover anything.
Hi @DeSilvaMPD
Welcome to the community forums ![]()
k6 distributed test execution assumes you will be running the test on Kubernetes. So there is no way to run those in bare EC2 machines. They should “belong” to a Kubernetes cluster using the k6-operator. Alternatively you could run this on the k6 cloud. For example, you can run this on EKS.
That is to say, if you need to run the scripts in a distributed fashion.
You should find more information in:
- GitHub - grafana/k6-operator: An operator for running distributed k6 tests..
- The Running distributed k6 tests on Kubernetes tutorial.
- A concrete example in my colleague Paul’s repo: GitHub - javaducky/demo-k6-operator: Project for demonstrating the use of k6-operator within Kubernetes clusters. which was discussed during the k6 Office Hours.
I hope this helps. Let us know if you have further questions or doubts.
Cheers!
