How to implement distributed stress testing with k6?
How to implement distributed stress testing with k6? Pls provide a guide.
Hi @sunnini
As mentioned on the community slack, you can use the operator on kubernetes: Running distributed k6 tests on Kubernetes
I hope this helps.
Cheers!
In addition to running distributed stress testing on k8s, can it run on multiple local servers? For kubernetes, we also need to build and deploy it, the operation is complicated.
Hi @sunnini
At this time the operator is the way to run distributed oss k6 tests that I would recommend, and it runs on Kubernetes. I do not know of other OSS alternatives. Maybe the community can help you out on that.
You also have the alternative to run on k6 Cloud.
Best,
