I want to use the particular pannel but i only want to use the only required variable for particular pannel.
@devanshutiwari Check out the Variables panel, which allows to display of relevant variables as a separate panel:
This is about the panel , but i want to know about the dashboard variable so that it should not visible in the non required panel
Variables are configured at the dashboard level not the panel level. Panels will see all the dashboard variables.
