label_values(kube_pod_status_phase{namespace=~"$namespace",cluster="$cluster",phase=“Running”},pod)
This shows all pod which includes, failed and couple of pods are repeating.
Actually I need to run above query, means running pod in the cluster?
kube_pod_status_phase{cluster=“isoft”,phase=“Running”}>0 this query returns running pod
The label_values
function extracts labels from a Prometheus metric for using in template variables in Grafana. The second parameter specifics which label (pod in your case) will return a list of pod names which have are in the Running phase - otherwise something is wrong.
How are you using the label_values function in your dashboard?
