I have a dashboard with below configuration.
Variables:
This should always return a default namespace, and it does.
query: label_values(kube_deployment_metadata_generation, namespace)
Regex: /.*default.*/
This should only return deployment with name master
OR worker
query:label_values(kube_deployment_metadata_generation{namespace="$deployment_namespace"}, deployment)
Regex: /.*master|worker.*/
Graph metric:
avg(irate(container_cpu_usage_seconds_total{pod_name!="", pod_name=~"$deployment_name.*", namespace="$deployment_namespace"}[5m]) * 100) by (pod_name)
The issue:
If I select deployment called worker-xxxxx, the graph should only show me pods from that deployment.
This works fine but if worker
or master
deployment doesn’t exists, the deployment_name
variable return none
. This causes the graph to show cpu for all the pods.
I think the issue is here: pod_name=~"$deployment_name.*"
so when deployment=none
it shows all pods, but I’m not sure how to include regex there.
Something like this doesn’t work: pod_name=~"$deployment_name.*/(worker|master)/.*"
Any help appreciated.
Update:
This seems to be working and results looks correct:
pod_name=~"$deployment_name.*master.*|.*worker.*"
