Using regex in Grafana templating - how?
I would like populate values for variable in templating using query (a datasource: Prometheus). I know that I can use structure like:
label_values({job="nodes"},instance)
and I received something like: node1.example.com:9100, node2.example.com:9100, etc.
But I would like receive only the FQDN (without a collon and a port number) . Probably I can use for that the “Regex” field but I can’t prepare correct regex pattern.
Thank you in advance for any help.
I think this should work:
/([a-zA-Z0-9\.]+)/
[a-zA-Z0-9\.]+ matches lower and uppercase letters, numbers and dots. The brackets around them create a capture group so that it only returns the part that matches.
You can try this regex: /(.*):9100/
Good afternoon!
I would like a help, regarding the aggregation of the item coming from the same application.
Can anyone help?
label_values(node_load1,instance)
Regex /(.*[^:])[:]/
Regex /(.*[^:])[:]/
Regex /(.*[^:])[:]/
