How to use unit in man hs, laboral time, Hs/man
I have Windows 10 and Grafana V10.4.0.
We work with RPA bots and try to see how much time is saved with bots. We know how much time a person consumes in each different transaction,
For example.
1 transaction = 30 minutes of one person
1 transaction = 2 min from the bot
If we process 100 trx, a person took 3000 min → 50 hours → 6.25 business days or hours/man
I want to use that Hs/Man unit, is it possible?
I have the amount of minutes
You can specify any Unit you need in Grafana:
As for calculations, try to implement them using your datasource.
I dont find in the options, help me to find it!
you use some plugin?
Just type what you need in the Unit field:
Hs/Man
Great, thank you very much! I think i only can select the options y the drop down!
