How to use regex expressions on alias by section to display a short name instead override
I want to short a name displayed on my dashboard, I used overrided option but its very tired to use overrides for each value in my panel.
I want to know if I can use a regular expresion to short the name and be displayed for all my values.
I want to short the name displayed, I used the $tag_url option and that works but still having so much text, I used ovverides and it works but Its complicated to do so for each value
This is using overrides name displayed is shorter and visible
I know that there was regex rename planned for the transform tab, as a workaround you can work on your JSON file and inject override using bash regex.
Hope it helps.
Good Luck
Oh thats a good point! I will try to use it!
I also find this docoument, section Fields with name matching regex
Thank you so much !!
@wlargou
I am unable to find regex rename planned for the transform tab in Grafana transform tab.
Here are my environment details:
OS : Debian GNU/Linux 10 (buster)
Kernel : 5.10.0-0.deb10.16-amd64
GRAFANA: 7.3.6
GRAFANA_IMAGE_RENDERER_PLUGIN_TAG: v3.3.0
GRAFANA_NETDATA_PLUGIN_VERSION: 1.0.12
I have posted the query regarding my issue would you please help me to resolve this.
