Hi
I have some measurements in InfluxDB that are below:
measurement": "/netdata\\.(nvidia_smi\\.gpu[0-9]_gpu_utilization)\\.utilization/"
I am trying to show the NVIDIA GPUs utilisation etc. I have completed it with the help of this JSON Schema :
"aliasColors": {},
"dashLength": 10,
"datasource": "NetData",
"id": 23763571993,
"legend": {
"alignAsTable": true,
"avg": false,
"current": true,
"max": true,
"min": false,
"rightSide": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"links": [],
"nullPointMode": "null",
"pointradius": 5,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"targets": [
"alias": "$2",
"dsType": "influxdb",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"measurement": "/netdata\\.(nvidia_smi\\.gpu[0-9]_gpu_utilization)\\.utilization/",
"orderByTime": "ASC",
"policy": "default",
"query": "SELECT mean(\"value\") FROM \"netdata.nvidia_smi.gpu[0-9]_gpu_utilization.utilization\" WHERE $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": false,
"refId": "D",
"resultFormat": "time_series",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "max"
"tags": []
"thresholds": [],
"title": "GPU Utilization",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"decimals": null,
"format": "none",
"label": "percentage",
"logBase": 1,
"max": "100",
"min": "0",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": false
"gridPos": {
"x": 0,
"y": 119,
"w": 12,
"h": 7
"options": {
"alertThreshold": true
"fieldConfig": {
"defaults": {
"custom": {}
"overrides": []
"pluginVersion": "7.3.6",
"yaxis": {
"align": false,
"alignLevel": null
"timeRegions": [],
"bars": false,
"dashes": false,
"fill": 0,
"height": "",
"percentage": false,
"points": false,
"stack": false,
"steppedLine": false,
"timeFrom": null,
"timeShift": null,
"fillGradient": 0,
"hiddenSeries": false
There are multiple GPUs in the system, so I handled it like the following (please check the above JSON Schema):
"rawQuery": false,
And I’m trying to print each GPU name with the help of Alias By $ but it’s printing the positional argument from measurement.
I Need to print this like below:
gpu0 or GPU0
gpu1 or GPU1
gpu2 or GPU2
Instead of
gpu0_gpu_utilization
gpu1_gpu_utilization
gpu2_gpu_utilization
Because this legend takes up too much space, I am unable to view more graph details.
I’m trying to resolved it with the help already posted solutions but I’m unable to find these option in my Grafana version 7.3.6.
I am also unable to find the regex rename planned for the transform tab in Grafana.
Here are my environment details:
OS : Debian GNU/Linux 10 (buster)
Kernel : 5.10.0-0.deb10.16-amd64
GRAFANA: 7.3.6
GRAFANA_IMAGE_RENDERER_PLUGIN_TAG: v3.3.0
GRAFANA_NETDATA_PLUGIN_VERSION: 1.0.12
Additionally, is there have any parameter to show bus id instead of gpu0 etc ?
Please suggest a solution to this.
Thanks in advance !
