How to use plotly panel in Grafana for categorical boxplots?
According to 87948 Plotly can produce boxplots.
But how to make categorical boxplots rather than temporal? The names of the boxes (x-axis) remains a time label, but I would require other box names.
Thanks!
I solved it by generating the data as intended originally by plotly (Box plots in JavaScript) rather than as suggested by in Post 87948.
So, I use a query that generates the raw data, with their values, their groups (the box they belong to, string), and a label for each value (also string).
Then I use:
var groups = data.series[0].fields[0].values;
var vals = data.series[0].fields[1].values;
var labels = data.series[0].fields[2].values;
var uniqueGroups = [...new Set(groups)].sort();
const partition = (vals, labels, groups) => {
  return vals.reduce((acc, v, i) => {
    acc[uniqueGroups.indexOf(groups[i])][0][0].push(vals[i]);
    acc[uniqueGroups.indexOf(groups[i])][0][1].push(labels[i]);
    return acc;
  }, Array.from(Array(uniqueGroups.length), () => new Array(Array.from(Array(2), () => new Array(0)))));
var partitions = partition(vals, labels, groups);
var traces = [...Array(uniqueGroups.length).keys()].reduce((acc,v,i) => {
          acc.push({
            y: partitions[i][0][0],
            text: partitions[i][0][1],
            type: "box",
            jitter: 0.3,
            pointpos: 0,
            boxpoints: 'Outliers',
          return acc}, []
return {
  data : traces,
  config : {
    displayModeBar: false
  layout: {
    xaxis: {
      type: "float"
    yaxis: {
      title: "[sec]"
