I have a problem and found a solution by using custom grafana variables.
Normally with flux i cannot get more than 1000 variable values as dashboard variable filter.
But if i define 8000 variable values by creating custom variable on grafana manually, dashboard filter can search all 8000 values and bring in the selectbox.
So i have to use manuel custom variable in grafana.
Now my problem is updating this custom variable in certain time period. Probably everyday.
How can i update custom grafana variable value dynamically everyday.
A script will run and write new custom values seperated by “,” like this : “Server1,Server2,Server3,…,Server7998,Server7999,Server8000”
I need to fill below area with my scripts dynamically.
[Screenshot from Dashboard/Settings/Variables]
