Grafana 9.2
Ubuntu 20.04
InfluxDB 1.8
I have the following InfluxDB query (using InfluxDB 1.8):
SELECT "apower" AS power_state
FROM "pm_shelly"
WHERE time > now() - 30d
AND custom_id =~ /^shelly_122$/
tz('Europe/Zurich')
This yields a time-series like so:
This is the power usage vs. time of a device.
I would like to determine the total amount of hours that the device was turned on in the last 30 days.
I found this forum post. It suggests converting the original time-series to a series consisting of 0
and 1
(where 1
is turned on; he calls the time-series generator_usage
) and then use the integral function to obtain the total seconds with value 1
. This seems like a reasonable solution.
However, I am unable to figure out how to obtain a time-series with 0
and 1
from my original series. I have tried this:
SELECT
apower,
(apower >= 10)::int AS power_state
FROM "pm_shelly"
tz('Europe/Zurich')
where 10
would be the threshold in Watts, above which I consider the device as turned on. But this does not work with InfluxDB 1.8 and I have not been able to find good solution. (It was suggested by ChatGPT.)
I would greatly appreciate any input on how to achieve this!
