I need help understanding how Grafana handles panel-level custom time ranges versus the global dashboard time picker.
My requirement:
Each panel should be able to run on its own custom time range (e.g., 15m, 1h, etc.)
But when a user changes the Grafana dashboard time picker, all panels should automatically switch back to the global time range.
When switching back to a custom mode, each panel should again follow its own custom time window.
What I tried:
I used variables to define custom ranges.
But Grafana always gives priority to panel-level overrides over the dashboard time picker.
I want a way where:
Panels stay independent during “custom mode”
All panels sync when global time picker is used
What I’m looking for:
Is there a recommended way to:
Allow per-panel custom time ranges
BUT override them using the global dashboard time picker
Ideally through variables, transformations, or any best practice method
My dashboard setup:
Grafana version: 12.2.1
Panels using PromQL
Key question:
How can I ensure that panel-level custom time windows get overridden when the dashboard time picker is changed, but still work normally when in custom mode?
