v10.4.2, Linux -
Have some sort of Apache SuperSetDataSetconcept - store common part of query string and refer to it while building per-chart queries. -
I tried to use const/textbox hidden variables and refer to them in query as${common_part:raw}. Raw format preserves quotes in original query as is. -
What happened?
The problem is that variables used in common query are not substituted. Thiscommon_partquery uses dashboard variables inWHEREclause and I want them to be substituted with their values - it is like to apply “eval” tocommon_partcontent. -
Have a format that will apply eval to variable. Or have better native support for sharing common parts of queries.
Is there a way to store query and then refer to it in other queries as a sub-query?
