I want to define a constant variable which contains a query, based on another constant variable as subquery -
I now have to substitute the whole subquery instead of just the $[VariableName] -
What happened?
I always get an error -
I wanted to merge both the query and subquery into a unique variable -
It is something like:
SELECT TimeStamp, State, EventTrigger, lead(state) OVER (ORDER BY TimeStamp asc) as NextState, lead(EventTrigger) OVER (ORDER BY TimeStamp asc) as NextEventTrigger FROM ($All_Semi_Info) subquery1
Hi @jmatetx,
Welcome to the community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
I am not an expert with MySQL queries but we do have documentation which defines how to create template variables for the queries. It can at least give you some start to proceed.
Hopefully, other community members can help you out
