Simplified example
Tag | Date | hours |
sleep | June 16, 2025, 11:00 PM | 8 |
If i sleep at 23:00 till 7:00 on June 16 It is counted as i slept 8 hours on June 16 but thats wrong, it should count it as one hour splitting data by variable $CloseHour(00:00), Then adding remaining to next (June 17) column
Desired output
sleep | June 16 | 1 |
sleep | June 17 | 7 |
How can we achieve this? Is there any other solution?
Other unrelated information to problem. my data source have following columns : activity name, time started, time ended, duration, duration mins, tags, categories, comment
Data is in CSV format
I do not know any SQL but willing to invest time. So you can help me by telling me which topic to learn first to solve this problem.
