I have an sql database with timestamps every time an item is made, and there would be periods of time where no items are made.
I need to calculate the items/per throughput of this database. Right now I am using the following but I’m not entirely sure how accurate it is:
WITH time_gaps AS (
SELECT
date_time,
TIMESTAMPDIFF(SECOND, LAG(date_time) OVER (ORDER BY date_time), date_time) AS gap_seconds,
EXTRACT(HOUR FROM date_time) as hour_of_day
FROM mydb.machine_01
filtered_gaps AS (
SELECT
date_time,
gap_seconds,
CASE
WHEN hour_of_day >= 7 AND hour_of_day <= 22
AND gap_seconds < 100
THEN gap_seconds
ELSE 0
END as operational_gap
FROM time_gaps
SELECT
DATE(date_time) as day,
SUM(operational_gap)/3600 as uptime_hours
FROM filtered_gaps
GROUP BY DATE(date_time)
This basically takes the timestamp difference between all timestamps, filters out any where the time is after 10pm and before 7am (our operating hours) and also filters out timestamp differences of 100 seconds (I wanted to get rid of any large gaps in output since technically the machine is not operating if the timestamp differences exceed 100 seconds).
Is there a more accurate way of calculating this? I have this in Grafana and use an additional WHERE clause at the end for the time filter, so in Grafana it looks like:
WITH time_gaps AS (
SELECT
date_time,
filtered_gaps AS (
SELECT
date_time,
gap_seconds,
CASE
THEN gap_seconds
ELSE 0
FROM time_gaps
SELECT
FROM filtered_gaps
WHERE $__timeFilter(date_time)
