Calculate the time differance between all TimeDate values and chart
Grafana version 9.4.3
I have a query that returns two columns, a number and a time stamp. I would like to show instead calculate the time difference between the values, so this can be displayed as a bar chart highlighting the variation between each time stamp
SELECT TimeDate, Step as value FROM dbo.AGVstep
WHERE $__timeFilter(TimeDate) AND Program <> 0 AND Program in ($Program) and Step in ($Step) and AGV in ($AGV)
order by TimeDate asc
I would achieve this in excel by simply using each value and subtracting the previous
Can anyone advise how I can do this in Grafana?
Thanks
This is more of a sql query question than it is a grafana question.
That said what type of server is this? mysql, postgres?
mysql
Check out this function, try it out and if stuck let us know
Thanks for the help with the LAG function.
SELECT TimeDate,
       (DATEDIFF(SECOND, TimeDate, lag(TimeDate, 1)
       OVER (ORDER BY TimeDate desc))) as CycleTime
  FROM AGVstep
    AND Program <> 0
    AND Step in ($Step) and AGV in ($AGV)
Works as I hoped it would.
