with athena data source is there a way to sum all timestamp entries (field name “timestamp”) to one number which is a percentage of entries per minutes, meaning if
2024-03-11 01:10:00
2024-03-11 01:09:00
2024-03-11 01:08:00
2024-03-11 01:07:00
2024-03-11 01:06:00
2024-03-11 01:05:00
2024-03-11 01:04:00
2024-03-11 01:03:00
2024-03-11 01:01:00
the 2 minute is absent, and I want a query that will return a 90%
I’m not sure of what you are asking. But as I understand it, you could just count the number of field you have:
SELECT COUNT(DISTINCT timestamp) FROM your_table_name
and then perform your percentage calculation?
Regards
not quite, Let’s suppose I always should have 1-2 entry per minute, but if I don’t - it means something went wrong. And I want to know the ratio of success/failure here
I already make use of DISTINCT DATE_TRUNC('minute', "timestamp") as timestamp to make sure I only select 1 message per minute, but not sure how to:
- detect if there is a gap and how
- account for it in the end percentage number
Also, I do not know if there a way to take each 5 min or take each 5th row?
Ok, will try, I had no idea grafana can be so different depending on datasource.
