How to show the trend over one hour samples?
Sorry, I am a bit of a newb when it comes to graphing. I’m lacking vocabulary, other than I want this to look nicer as explained in the video above.
How do I make the resolution of the bar, one hour? How do I draw a “trend line” across the top?
Thank you,
Hi Hendry!
Could you please post an additional screenshot of the “Visualisation” tab (the button just underneath the “Query” tab you have selected currently (in Orange)?
This will help us understand where you are now, and how to get you to where you want to go :slight_smile:
I figured it out. I needed 1hr min step!
Can you post your text or saved json?
I’m about to try this but the video is hard to read, so I’ll have to lookup the specifics elsewhere.
