this
Welcome @folkford2544
Do you have this setting under Show Values? I do not know of a way for Grafana to automatically display sum or % here, but you could potentially adjust your query to give those values instead and then Grafana should be able to display them.
Might also look at apache chart grafana plugin
Did you find a solution?
check this out
