When using the Graph visualization, do the hoover tooltip values change to the percentage ratios when “Percent” is selected under Stacking?
Example: Stacked Chart values… A=6, B=12, C=2 …when Percent is turned on, should I be seeing A=30%, B=60%, C=10% via the hoover tooltip?
Percent under Stacking is checked, but I am still seeing the raw numbers. The only thing that changes are the labelling & scaling of the y-axis. I was expecting to see the displayed values also change to ratios. Any thoughts? Thanks!
