How to share data between Dashboards?
I can share data between panels using variables in one dashboard. But how to share data between dashboards? For example, share the global custom theme, background image url, and some css configurations.
Hi @yangliuyu
Can you share some more info? What version of Grafana are you running? And it sounds like are modifying the source code. Is that correct? Thanks!
I use grafana 7.5.9 and I’m developing new panel plugin. I want to store some global configuration between dashboard thereby I don’t need to define them in each dashboard repeatedly. For example I want to define some theme color, background image and font family/font size between dashboard with same value.
I don’t know how to set these values, period, let alone as global configuration options. Are these things you are setting in your panel plugin? Perhaps some screenshots would help…
