Hello there,
I’m creating 2 custom plugins. how can I share objects between the panels instances?
let’s say I have one panel to create a web socket and pass it to the other panel to use it.
is there a way for this?
like mixin or react context for example.
I don’t believe there’s an easy way to do this. To communicate between panels, you could use a dashboard variable. Panels using a variable update whenever its value changes, so you could effectively use it to pass (simple) values between panels.
That being said, I’m pretty sure you wouldn’t be able to share a web socket this way. You’d need some form of shared storage between panels which, to the best of my knowledge, isn’t available to plugins.
