I want set like this.
Ref. of image: https://www.researchgate.net/figure/The-bar-chart-showing-the-monthly-water-vapor-density-for-Ebonyi-state_fig4_323634510
Now, I set time shift of this month and I must edit every month.
example this month is June, I created graph by set this month, and created by set time shift 1M, and created by set time shift 2M, …
I want to set absolute time range: Jan, Feb, Mar, …, Dec of previous and this year.
it looks like you might want to use the Bar Chart, which can use arbitrary strings on the x axis:
https://play.grafana.org/d/ktMs4D6Mk/5-bar-charts-and-pie-charts?orgId=1
See the docs for the data model that you will need to fit:
Thank you for your answer but I still cannot do it
- I used Bar Chart already
- My data is 1 fieldname
- Storage data since about 5 months ago
I want separate my data to each month
I separate by set time shift but this method will set again every month
What is your datasource? Could you please provide sample data for what you are trying to chart?
My data source is InfluxDB.
I got data active power (kW) every 1 minute. After that, I calculated by /60 (kW to kWh).
I want to bring Total kWh each month show on bar chart like your graph.
Thank you
Please provide the above in csv format?
I generate csv format already but I do not know how to post csv format.
It show that
“Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, heic, heif, webp)”
like following
_field,_value,_measurement
waterlevel,133.5,_ocean
I do not know how to get that format but I create this on excel.
Data range: 01/03/2022 to 31/05/2022
I want to separate sum of March, April, May to bar graph
type 3 ticks → ` <— before and after the data you want to post
