Hi, I´m using Grafana in home assistant and my database is influxDB.
I created some bar charts with time range of last 2 or 3 years, as you can see in the picture:
Is it possible to have each month compared side by side to same month from the other years.
For example:
Jan/2023
Jan/2024
Jan/2025
Feb/2023
Feb/2024
Feb/2025
Is this possible?
yes it is possible using transformation and unit setting in bar chat panel , please follow the steps..
Step 1: Configure the bar chat visualization panel
Hi, and thank you for supporting me.
I didn´t have the value “Date” in the drop downs or somewhere else. I only have the option “Time”, but when I use Time, instead of Date, it didn´t work.
