How to restart Grafana in Kubernetes
Hi All,
How to restart Grafana in Kubernetes after i installation plugin.
Please tell me either pod, services, deployment what need to restart so that my plugin should show in Grafana Plugin GUI
Hi @mohdrashid01
Two things:
I have used this hacky workaround to restart grafana in a k8s pod:
But with grafana v8 there is now a plugin admin feature in beta. You should turn on the config option and check it out as the server admin user. It allows for the live browsing and loading of plugins inside the app–no restart necessary.
