How to reset time picker to dashboard default?
I would like to know if it’s possible to easily reset the time picker to the dashboard default.
If my dashboard is set to 6h by default and I pick something else, either by zooming into panels or manually setting a time range with the time picker - how do I revert it to the dashboard default, which is 6h ?
I could manually use the time picker to set it to 6h, but I might not even know that 6h is the default.
In 11.2 it was possible to just klick “Home” at the top left - if it was the standard dashboard the time picker would automatically reset to 6h. That was super easy to do.
After upgrading to 11.5 this is no longer the case, the selected time range does not reset.
you can add a dashboard link that links to itself and remove the:
&from=now-15m&to=now
from the url…
