Hello All,
I have my data displayed as
Visualization - Stat,
Displaying - Last row
and override few columns unit to currency.
By default all values got applied with units like ‘K’ for thousands amount.
How can I remove the default unit as I need to show the exact number value?
Below is an example of my problem
I need to display $1600 but it shows $1.600K.
I checked the decimal option but it does not help with removing ‘K’ unit. And also, I tried with readjusting the whole panel size(by dragging and giving sufficient spacing for the columns), but it doesn’t help as well.
Please suggest.
Regards,
Sudeep
