Regarding Grafana Visualization
I am using Grafana 10.3.3
I have a drop down to select multiple metrics ( For some the unit is number …and for some the unit is percentage )
Is there any common visualization type in grafana which would be appropriate for both numeric and percentage values ?
Any suggestions ?
Please let me know.
Thanks,
Nilanjan
almost any visualization should be OK with the usage of overrides
Hi ,
Could you please elaborate how to use the overrides here ?
Any visualization type you can suggest would suit both numeric values and percentage values in Grafana?
Would the “Stat” visualization type suit percentage values also …?
Please let me know.
Thanks,
Nilanjan
See an example:
