Hey guys, i’m new in this area of monitoring stuff…
I’m doing a class of grafana and seeing this is a powerfull tool. I wonder if it’s possible to use Grafana for show others things besides metrics… I want to create diferent types of visualizations doing some SELECT in my database, where I have a lot of information about the employees, for example… but it is not working properly…
It’s possible to create others types of graphics and visualizations(others things) with grafana or it only works with devices?
Welcome.
Such as?
Tell us what you’re trying to achive, show us how you’re trying to do it, and
tell us what isn’t working as you expect.
Then we might be able to help, either to achieve what you want, or to let you
know where Grafana’s limitations are.
At present you’re telling us “I’m trying to do something different and it isn’t
working”. We have no idea what you’re doing or how it’s failing.
Grafana works with any information you can get into your back-end data store.
However, I suspect you’re really asking about the type of visualisation panels
which Grafana has available, for representing your data.
Try giving us some examples of the data you want to represent, and how you
would like it to be shown, and we might have some ideas for you.
