I am using Grafana as an add-on in Home Assistant (version 10.2.2). Home Assistant is running on Debian 12.
I want to display sensor values on a floor plan so that the values change color depending on their readings and remain correctly positioned on the plan.
I am using the Canvas panel plugin in Grafana with a background image of my building’s floor plan. The sensor values are stored in InfluxDB.
What happened?
I encountered an issue with background image scaling.
- If I set Background image size to “Fill”, the image gets distorted on different devices due to varying aspect ratios.
- If I use “Original size” or “Tile”, the image does not fit properly on some screens.
- If I set it to “Contain” or “Cover”, the overlay elements (sensor values) shift when the screen size changes, making them misaligned with their actual positions in the building.
I expected the sensor values to stay in their correct positions on the floor plan, regardless of the screen size or resolution.
I can provide additional configuration details if needed.
There are no specific errors, but the misalignment issue makes the visualization inaccurate.
I searched for solutions but haven’t found a clear answer.
Question:
How can I ensure that my sensor values remain correctly positioned on the floor plan while maintaining a properly scaled background image? Should I adjust Canvas settings, use a different approach, or is there a better plugin for this task?
Thank you in advance for your help!
