kshull
April 16, 2021, 8:31pm
1
I have two elasticsearch index per environment. One for dev and int and another for prod.
There are two sets of these indexes, 1 set for dev and int and another set for prod.
Each of these indexes is mapped as a data source in Grafana.
I want the Grafana to be able to use the correct set of indexes if they select either dev, int or prod.
How can I have Grafana select to correct set of indexes when the user selects a particular?
Thanks
Kurt
Are you saying that you want to have a dashboard where the user can select dev/int or prod from a menu and then all panels on the dashboard will load the related index?
kshull
April 20, 2021, 9:17pm
3
Yes, exactly.
User selects “dev”, grafana points to index2
User selects “int”, grafana points to index2
User selecta “prod”, grafana pointes to index1
Hi @kshull ,
You should be able to accomplish this using variables.
I would check out this tutorial and see if it helps.
