I have a query variable that allows the user to select which environment’s data to view. Specifcally:
Variable name: environment
Possible values: dev, int or prod
Based on the users selection my variable will end up containing one of the 3 environments specified above.
Now, what I’d like to do is select a specific ElasticSearch database based on one of these environments. The reality is that I have two data sources. One is for the dev/int environments and the other is for the prod environments.
So if a user selects “dev” or “int” I want to point to the dev datasource and if they select “prod” I want to select the prod datasource.
How can I do this? There must be a way.
