How To Place Company Logo
Hi all,
i would like to display our company logo in Grafana dashboard ,
please help me some one how to add that logo.
any help would be appreciate.
Hi sivaprasad,
When you have a Text panel, you can edit it being able to add an image or logo with HTML code. You can find out here: https://www.w3schools.com/tags/tag_img.asp one way of using images.
Hi Sergioc,
Thanks for quick reply , actually my concern is
like this i need place .
You can change it. Search the file name of that grafana image and replace it with your image.
as manik mentioned, you can swap the file for your company logo but it will get stomped after each upgrade.
Ya thanks it working for me
Hi Manik ,
the above image is not showing proper values , look at marked point , actually That is total processing time = 1 minute , but its laying on 3MIns line , can you please explain this if you have any idea . thanks in advance .
Regards
siva Prasad
You should start a new topic for a new issue that’s unrelated to the original topic. However, it looks like you’ve got a stacked graph.
Can u pls let me know the step by step process. It’s urgent and client requirement.
