I have Grafana fetching this data from MySQL
hits {metric="58850", title="Foo bar", url="example.com/something&foo=1"}
In the Grafana charts, I’m interested in only showing the title, without quotes Foo bar. As far as I can tell, this can be done using grafana filter by name via Regex. But I don’t know what Regex to use.
I tried to use the example on Grafana official website, but that it’s not working
As you can see, it’s not working.
/.*title="([^"]*).*/
I would use Label configuration in the query tab (so no transformation). Set {{title}} there and only title label will be used as a metric label (name) in the Grafana.
Would I be able to get the url and my metric?
The metric and url in this example are used to create data links so i need them.
You can use multiple labels there and you can customize for your needs, e.g.{{url}} {{title}}, {{url}}-{{title}},url={{url}} title={{title}}, …
thank you so much, im currently on vacation, will try that in few days when i get back to work. Thanks
