Grafana - Using a variable as regex in Prometheus query
Hi all,
I’m new on Grafana and I’m trying to figure out how I can use a variable regexp in a Prometheus query
My variable is about mssql instance name - sql_instance in server:instance format
I would like to use the first part of the variable ( before : ) to be used as parameter in the following query:
win_cpu_Percent_Processor_Time{host="sql_intance_first_part",exported_instance='_Total'}
Can anyone put me on the right track ?
Thanks in advance
Just to update this thread, I changed finally the way to create my variable.
Instead of using directly the mssql instance name, I use both label_replace() function and label correletion AND ON to address my need
Regards
