How to minimize top bars in Grafana 11.5
The new layout has changed the screen estate, so that there are now 2 top bars (both the Grafana and Dashboard toolbars) instead of just 1. Is it possible to change this, so that there is not so much wasted screen estate in the top? I would like to toggle the 2nd top bar on and off (the Dashboard toolbar with “Make editable”, “Export” etc.) with the default being off.
Is this possible with 11.5? I’m pretty sure this could be toggled previously.
It seems this has been fixed in Grafana 13, where the top layout is finally optimized again. Thanks!
hello @ameinild thanks for the update.
