How to make HTML change be effective
I changed /usr/share/grafana/public/app/features/org/partials/newOrg.html. After restart grafana-server, the change is not reflected on the GUI.
How shall I need to do after updating this file?
Thanks,
Ming Li
hey,i wann know if you have solved the problem.cause i have same problem.
Because grafana frontend is based on webpack, each html change needs to do npm build as following:
yarn install --pure-lockfile
yarn watch
After that, you can do the below steps to generate rpm:
go run build.go build package
To reinstall rpm, you can get the frontend change.
thanks a lot !
i will try.
are u chinese,please?
hi,when i run ‘yarn watch’ in the project。
i see 'Couldn’t find a package.json file in “D:\grafana-5.4.3” ’
And i do not see any package.json file in the project。
Could you help me .
