Docker grafana/grafana:7.5.3 -
I want to restrict the max time range that users can retrieve data. -
What happened?
A user can select a time range, for example, of 10 years. This is unnecessary and it’s causing troubles for us. -
I would like to have a configuration option to limit a dashboard to only retrieve data in a maximum range of 30 days. I also would like to limit him to not get data older, for instance, than 6 months.
I saw a PR that’s been reviewed to do that, but I don’t know when/if It’ll come. Can anyone give me pointers in what options do I have to resolve my problem? If there is a new feature in recent versions or if it’s possible to make it as a plugin, etc.
Best regards!
and welcome to the forum,
