Grafana OSS v6.7.4 (I can update if there is a solution in a newer version), windows - What are you trying to achieve?
Setting time range to be maximum 1 week - How are you trying to achieve it?
When the user selects a start time, the end time should be at most 1 week from the start time - What happened?
Due to large amount of data to be loaded, I want to limit to maximum 1 week so that data can be loaded fast and 1 week of data is enough for my dashboard
welcome @capybara123
upgrading is recommended but does not necessarily solve your specific problem
What data source do you have?
As you can see in a more recent version of grafana it has a from and to time range
Thanks for the reply. I’m getting data from PostgreSQL. Yes I’m seeing this time range selection in my current version. But it’s an arbitrary time range and I want to limit it to max 1 week.
starting from what date? or what static date ranges?
