- Grafana version : v.9.0.4
- Grafana environment : Kube-prometheus stack
I want to use some grafana plugin in public repository.
I use grafana as container then it is hard to use wget.
If i want to use grafana plugin in environment of container is there way or guide?
Please let me know.
kubectl get pod -n monitoring | grep grafana
grafana-c48f6bbc4-d4nmn 1/1 Running 0 144m
$ kubectl describe pod grafana-c48f6bbc4-d4nmn -n monitoring
Namespace: monitoring
Priority: 0
Node: dkhiopsinf03/10.166.204.96
Start Time: Tue, 04 Oct 2022 12:38:30 +0900
Labels: app.kubernetes.io/component=grafana
app.kubernetes.io/name=grafana
app.kubernetes.io/part-of=kube-prometheus
app.kubernetes.io/version=9.0.4
pod-template-hash=c48f6bbc4
Annotations: checksum/grafana-config: 563127ddafae4dbd41e35c080ed5b739
checksum/grafana-dashboardproviders: 48f241f5bee2d4de7b5f833ab5906aad
checksum/grafana-datasources: a50d2496f51102900b8bdd577b4aed6a
cni.projectcalico.org/containerID: 8a5d5932df10c6c01c362207fcef2f3f73e510f7b86c2ad5e9905a4a3bc3028b
cni.projectcalico.org/podIP: 192.175.100.190/32
cni.projectcalico.org/podIPs: 192.175.100.190/32
Status: Running
IP: 192.175.100.190
IPs:
IP: 192.175.100.190
Controlled By: ReplicaSet/grafana-c48f6bbc4
Containers:
grafana:
Container ID: containerd://caa7906aace888091ad5116035957f89f2f8ed6d9713d7e8a729a3156b2a8596
Image: dcr.cloud.samsungds.net/dspaas-v1.22.10-a/grafana/grafana:9.0.4
Image ID: dcr.cloud.samsungds.net/dspaas-v1.22.10-a/grafana/grafana@sha256:c065bb100e0727c555fb62d5763870b20c30d16a59f3d4188090f0ede75d6e4d
Port: 3000/TCP
Host Port: 0/TCP
State: Running
Started: Tue, 04 Oct 2022 12:38:43 +0900
Ready: True
Restart Count: 0
Limits:
cpu: 200m
memory: 200Mi
Requests:
cpu: 100m
memory: 100Mi
Readiness: http-get http://:http/api/health delay=0s timeout=1s period=10s #success=1 #failure=3
Environment:
Mounts:
/etc/grafana from grafana-config (rw)
/etc/grafana/provisioning/dashboards from grafana-dashboards (rw)
/etc/grafana/provisioning/datasources from grafana-datasources (rw)
/grafana-dashboard-definitions/0/alertmanager-overview from grafana-dashboard-alertmanager-overview (rw)
/grafana-dashboard-definitions/0/apiserver from grafana-dashboard-apiserver (rw)
/grafana-dashboard-definitions/0/cluster-total from grafana-dashboard-cluster-total (rw)
/grafana-dashboard-definitions/0/controller-manager from grafana-dashboard-controller-manager (rw)
/grafana-dashboard-definitions/0/grafana-overview from grafana-dashboard-grafana-overview (rw)
/grafana-dashboard-definitions/0/k8s-resources-cluster from grafana-dashboard-k8s-resources-cluster (rw)
/grafana-dashboard-definitions/0/k8s-resources-namespace from grafana-dashboard-k8s-resources-namespace (rw)
/grafana-dashboard-definitions/0/k8s-resources-node from grafana-dashboard-k8s-resources-node (rw)
/grafana-dashboard-definitions/0/k8s-resources-pod from grafana-dashboard-k8s-resources-pod (rw)
/grafana-dashboard-definitions/0/k8s-resources-workload from grafana-dashboard-k8s-resources-workload (rw)
/grafana-dashboard-definitions/0/k8s-resources-workloads-namespace from grafana-dashboard-k8s-resources-workloads-namespace (rw)
/grafana-dashboard-definitions/0/kubelet from grafana-dashboard-kubelet (rw)
/grafana-dashboard-definitions/0/namespace-by-pod from grafana-dashboard-namespace-by-pod (rw)
/grafana-dashboard-definitions/0/namespace-by-workload from grafana-dashboard-namespace-by-workload (rw)
/grafana-dashboard-definitions/0/node-cluster-rsrc-use from grafana-dashboard-node-cluster-rsrc-use (rw)
/grafana-dashboard-definitions/0/node-rsrc-use from grafana-dashboard-node-rsrc-use (rw)
/grafana-dashboard-definitions/0/nodes from grafana-dashboard-nodes (rw)
/grafana-dashboard-definitions/0/nodes-darwin from grafana-dashboard-nodes-darwin (rw)
/grafana-dashboard-definitions/0/persistentvolumesusage from grafana-dashboard-persistentvolumesusage (rw)
/grafana-dashboard-definitions/0/pod-total from grafana-dashboard-pod-total (rw)
/grafana-dashboard-definitions/0/prometheus from grafana-dashboard-prometheus (rw)
/grafana-dashboard-definitions/0/prometheus-remote-write from grafana-dashboard-prometheus-remote-write (rw)
/grafana-dashboard-definitions/0/proxy from grafana-dashboard-proxy (rw)
/grafana-dashboard-definitions/0/scheduler from grafana-dashboard-scheduler (rw)
/grafana-dashboard-definitions/0/workload-total from grafana-dashboard-workload-total (rw)
/tmp from tmp-plugins (rw)
/var/lib/grafana from grafana-storage (rw)
Conditions:
Type Status
Initialized True
Ready True
ContainersReady True
PodScheduled True
Volumes:
grafana-storage:
Type: PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
ClaimName: grafana-pvc
ReadOnly: false
Type: Secret (a volume populated by a Secret)
SecretName: grafana-datasources
Optional: false
grafana-dashboards:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
tmp-plugins:
Type: EmptyDir (a temporary directory that shares a pod’s lifetime)
Medium: Memory
SizeLimit:
grafana-dashboard-alertmanager-overview:
Optional: false
grafana-dashboard-apiserver:
Optional: false
grafana-dashboard-cluster-total:
Optional: false
grafana-dashboard-controller-manager:
Optional: false
grafana-dashboard-grafana-overview:
Optional: false
grafana-dashboard-k8s-resources-cluster:
Optional: false
grafana-dashboard-k8s-resources-namespace:
Optional: false
grafana-dashboard-k8s-resources-node:
Optional: false
grafana-dashboard-k8s-resources-pod:
Optional: false
grafana-dashboard-k8s-resources-workload:
Optional: false
grafana-dashboard-k8s-resources-workloads-namespace:
Optional: false
grafana-dashboard-kubelet:
Optional: false
grafana-dashboard-namespace-by-pod:
Optional: false
grafana-dashboard-namespace-by-workload:
Optional: false
grafana-dashboard-node-cluster-rsrc-use:
Optional: false
grafana-dashboard-node-rsrc-use:
Optional: false
grafana-dashboard-nodes-darwin:
Optional: false
grafana-dashboard-nodes:
Optional: false
grafana-dashboard-persistentvolumesusage:
Optional: false
grafana-dashboard-pod-total:
Optional: false
grafana-dashboard-prometheus-remote-write:
Optional: false
grafana-dashboard-prometheus:
Optional: false
grafana-dashboard-proxy:
Optional: false
grafana-dashboard-scheduler:
Optional: false
grafana-dashboard-workload-total:
Optional: false
grafana-config:
SecretName: grafana-config
Optional: false
QoS Class: Burstable
Node-Selectors: kubernetes.io/os=linux
node-type=infra
Tolerations: node-role.kubernetes.io/infra:NoSchedule
node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
What happened?
