How to install grafana on centos7? I know the step by step but it's not working
PROBLEMA INSTALAÇÃO DO GRAFANA NO CENTOS7
Comandos
Desabilitando o SELinux
vim /etc/sysconfig/selinux
wget https://dl.grafana.com/oss/release/grafana-6.2.4-1.x86_64.rpm
Baixando com esse comando da o seguinte erro:
sudo yum localinstall grafana-6.2.4-1.x86_64.rpm
Error: File contains no section headers.
file: file:///etc/yum.repos.d/grafana.repo, line: 1
‘name=grafana\n’
Quando tento iniciar também aparece
systemctl start grafana-server
Error: Failed to start grafana-server.service: Unit not found.
Eu já tinha instalado , estava rodando no terminal só que parou de funcionar, estou usando o centos7.
PROBLEM INSTALLING GRAFANA ON CENTOS7
commands
Disabling SELinux
Downloading with this command gives the following error:
Error: The file does not contain section headers.
‘name=grafana\n’
When I try to start it also appears
Error: Failed to start grafana-server.service: Drive not found.
I already had it installed, it was running in the terminal but it stopped working, I’m using centos7.
Hi @vitoriadelaraestudo, welcome to the :grafana: community.
It seems to be a problem that you want to install an older version of grafana ver.6.2.4 but you also have a repo file which might be getting conflict when using yum to install it.
The easiest way is to rename the repo file //etc/yum.repos.d/grafana.repo to something like //etc/yum.repos.d/grafana.repo.bak
and then do the following;
login as full root;
su -
then run this command
Then it should be all fine.
