Attempted to upgrade from 4.1.2 to 4.2.0 CentOS 7
I attempted to upgrade our grafana server from 4.1.2 to 4.2.0 and broke my installation. VM is running CentOS 7.
Commands Ran:
$ wget https://s3-us-west-2.amazonaws.com/grafana-releases/release/grafana-4.2.0-1.x86_64.rpm
$ sudo yum install initscripts fontconfig
$ sudo rpm -Uvh grafana-4.2.0-1.x86_64.rpm
$ sudo systemctl daemon-reload
$ sudo service grafana-server start
Current Error Message:
grafana-server.service: main process exited, code=exited, status=1/FAILURE
Unit grafana-server.service entered failed state.
grafana-server.service failed.
grafana-server.service holdoff time over, scheduling restart.
start request repeated too quickly for grafana-server.service
Failed to start Grafana instance.
Did you check the grafana.log (usually at /var/lib/grafana/grafana.log)
